DAVESUD
Jul 11, 2022Aspirant
Trying to connect Tesla PowerWall
Powerwall won’t connect because it needs a 2.4ghz network. Any thoughts for a workaround?
Jul 11, 2022Guru - Experienced User
What are you trying to connect it to?
Pretty much all netgears routers have 2.4ghz.
Its usually just an issue of making sure the device you're trying to use for going through setup is actually connected to the 2.4ghz. (actually lazy coding on the app part)
