DAVESUD
Jul 11, 2022Aspirant
Trying to connect Tesla PowerWall
Powerwall won’t connect because it needs a 2.4ghz network. Any thoughts for a workaround?
Jul 13, 2022Guru - Experienced User
Make sure the iphone is connected to the 2.4ghz. I've seen this done by either turning down the 5ghz broadcast strength and moving a ways away to even adding in the "disable 5ghz ssid" broadcast (doesn't turn off the radio. Then disconnect, reconnect and see if you're connected to the 2.4ghz.
Also, make sure icloud relay and private mac/ip address are disabled. thats caused issues before too.
What modem/gateway is the orbi connected to?
DAVESUD
Jul 13, 2022Aspirant
How do you verify that phone is on 2.4Ghz?
My router is connected to a local provider via a little modem connected to a microwave antenna. I have connected many IoT 2.4 ghz successfully.
- CrimpOnJul 13, 2022Guru - Experienced User
I have read several more Tesla articles about connecting the Gateway 1 to WiFi.
All of them mention
- Connecting first to the Gateway itself using the credentials printed on the panel.
- Telling the Gateway to scan for local WiFi networks.
- Entering the WiFi password so that the Gateway can log into the local WiFi
https://www.tesla.com/support/energy/powerwall/own/monitoring-from-home-network
This article specifically says that the Gateway does the searching. It cannot become confused over 2.4G vs 5G because it has only a 2.4G radio in it.
The articles mention several times the need for "at least two bars" of WiFi strength. Do you have a means to measure the WiFi signal strength at the PowerWall?
- plemansJul 14, 2022Guru - Experienced User
Cheat. do you have someone with another phone around you? If so, shut off your router/satellite and have them setup their phone with a hotspot that has the exact same ssid/password as your router but only have them setup the 2.4ghz hotspot. Then use your phone to setup the tesla to connect to their hotspot. Once it goes through setup, have them shut off their hotspot and turn your router/satellites back on. It should auto-connect. I've used this method before with devices that struggled to connect to mesh systems.
- DAVESUDJul 14, 2022Aspirant
This sounds like a plan. But I don’t see a way to set an ssid for the iPhone hotspot. Password yes, ssid no. My wife has an iPhone that we could use v
I meet all the requirements. 5 bars of WiFi. When it tries to connect to my network, doesn’t ask for a password!?
- CrimpOnJul 14, 2022Guru - Experienced User
Every set of instructions I have found say that the user has to enter the WiFi password.
https://www.tesla.com/support/energy/powerwall/mobile-app/connecting-powerwall-wi-fi
I was a bit surprised to see this comment:
On all of my WiFi devices, once I have entered a correct password once, the device remembers it and I never have to enter it again. This helps when I visit someone who told me their WiFi password months ago. Just walk in, select their WiFi, and it connects. Can you make a screen shot of the error message that comes up (after more than five minutes)? (Wouldn't it be a hoot if the PowerWall is already connected and just hides the information?)
I like the idea of creating a temporary Hot Spot using a cell phone, as long as the cell phone creates a 2.4G Hot Spot. That is what my Sony Xperia does. Have no idea what frequency iPhone Hot Spots are.
How to change your WiFi SSID or WiFi name of your iPhone hotspot - Techcoil Blog
I don't have a iphone so this is just from googling quick.
