DAVESUD
Jul 11, 2022Aspirant
Trying to connect Tesla PowerWall
Powerwall won’t connect because it needs a 2.4ghz network. Any thoughts for a workaround?
DAVESUD
Jul 13, 2022Aspirant
How do you verify that phone is on 2.4Ghz?
My router is connected to a local provider via a little modem connected to a microwave antenna. I have connected many IoT 2.4 ghz successfully.
CrimpOn
Jul 13, 2022Guru - Experienced User
I have read several more Tesla articles about connecting the Gateway 1 to WiFi.
All of them mention
- Connecting first to the Gateway itself using the credentials printed on the panel.
- Telling the Gateway to scan for local WiFi networks.
- Entering the WiFi password so that the Gateway can log into the local WiFi
https://www.tesla.com/support/energy/powerwall/own/monitoring-from-home-network
This article specifically says that the Gateway does the searching. It cannot become confused over 2.4G vs 5G because it has only a 2.4G radio in it.
The articles mention several times the need for "at least two bars" of WiFi strength. Do you have a means to measure the WiFi signal strength at the PowerWall?
- DAVESUDJul 14, 2022Aspirant
I meet all the requirements. 5 bars of WiFi. When it tries to connect to my network, doesn’t ask for a password!?
- CrimpOnJul 14, 2022Guru - Experienced User
Every set of instructions I have found say that the user has to enter the WiFi password.
https://www.tesla.com/support/energy/powerwall/mobile-app/connecting-powerwall-wi-fi
I was a bit surprised to see this comment:
On all of my WiFi devices, once I have entered a correct password once, the device remembers it and I never have to enter it again. This helps when I visit someone who told me their WiFi password months ago. Just walk in, select their WiFi, and it connects. Can you make a screen shot of the error message that comes up (after more than five minutes)? (Wouldn't it be a hoot if the PowerWall is already connected and just hides the information?)
I like the idea of creating a temporary Hot Spot using a cell phone, as long as the cell phone creates a 2.4G Hot Spot. That is what my Sony Xperia does. Have no idea what frequency iPhone Hot Spots are.
- plemansJul 14, 2022Guru - Experienced User
How to change your WiFi SSID or WiFi name of your iPhone hotspot - Techcoil Blog
I don't have a iphone so this is just from googling quick.
