ptdurfee
Aug 27, 2021Aspirant
trying to decide what to buy to reach my barn
I have an RBR50 Orbi router, plus a satellite in my house. The satellite does not reach my barn (150' away) with consistent signal. Should I buy another satellite and put it in the barn...
Aug 27, 2021Guru - Experienced User
The distance is too far for wireless. You'll need a buried CAT6A lan cable between the house and barn, then you could install a RBS via ethernet in the barn area.
ptdurfee
Thanks for that info. I do already have some signal there. Just trying to iprove it.
It may be a bit less than 150' also.
My question maybe is:
What will reach farther:
a satellite to satellite link, or
a range extender (repeater?) to satellite link, or
a satellite or extender to end user device ???
I am not concerned about data rates much as I am not a heavy user in the outbuilding.
Thanks again
- FURRYe38Aug 27, 2021Guru - Experienced User
If some signal is there, then it would a a low signal. Trying to extend or amplify this will not produce better signal. Your just amplifying a low signal at the extender point and at any time that single could be lost or not usable. You'd be amplifying a low signal with no much operation and performance so yes, connection rates between the low signal and the extender would be questionable. Connections to the extender would be good but past the extender to the house would probably not be good.
If you have a clear path from home to barn possible buried cable or hung cable should be reviewed.
You can take a look at this and see if this would work as well:
https://www.netgear.com/business/products/wireless/wireless-airbridge/wbc502.aspx
Thanks again
