mcd1956's avatar
mcd1956
Follower
Dec 25, 2019
trying to download firmware upgrade
trying to download and install the firmware upgrade but keep getting error messages saying disc is corrupted
1 Reply
  • CrimpOn's avatar
    CrimpOn
    At what point does the message appear about the disc being corrupted?
    There are several steps in doing a manual firmware update (loading a previous version is still an "update", ha)
    • Navigate to the Netgear web page with the desired firmware for the product.
      https://www.netgear.com/support/product/RBR20.aspx#download
      If you are have previously upgraded to a version that you are not happy with and want to "go back",
      click on the "View Previous Versions" to find the firmware you want.
    • Click on and download the firmware files for both router and satellite.
    • Extract (unzip) the ".img" file for both the router and satellite from the respective .zip files.
    • Update the satellite first.
    • --- Navigate to the Satellite web page.  The IP address of the satellite should appear on the list of "Attached Devices"
    • --- Log in with the usual credentials, "admin" and the administrative password
    • --- Select the bottom menu item, "Firmware Update"
    • --- When the web page asked you to Browse to and select the firmware file, navigate to wherever you extracted the .imp file
    • --- The process should complete
    • If there are more statellites, do the same thing on each.
    • Finally, update the router
    • --- Navigate to the Router web page
    • --- Click on the Advanced Tab
    • --- Click on the menu Administration
    • --- Click on the bottom menu item, Firmware Update
    • --- On the Firmware Update page, click on the Manual Update tab
    • --- Click on the button that asks you to Browse and select the firmware file
    • --- Find the router .img file and click on it
    • The process should finish and the router will reboot
    So, at which step does the error message appear?
