RodGolding
Nov 07, 2017Aspirant
Trying to get 1 gig out of my Orbi WiFi connection.
Just signed up with Comcast/Xfinity Gig service in the Houston area. I am using a Netgear CM1000 for a cable modem along with a Orbi RBK50/RBS50 system. The best I hve been able to get in WiFi is 350...
- Nov 07, 2017
Having the 2.4 GHz OFF makes no difference.
WiFi is inherently limited to 50-60% of the link rate. So, yes you can get more throughput if you use a combination of router and client device that both support a higher link rate than Orbi's 867 Mbps.
Orbi is designed for good coverage of a large area, not for peak speed for a single client connection.
Your Nighthawk claims to support a link rate of 2166 Mbps. This requires a client that supports 1024QAM modulation. It's unlikely you have a client that supports that. If you did, you'd need to use it very close to the router to get that link rate.
st_shaw
Nov 07, 2017Master
Your Orbi WiFi is working properly at near maximum speed. Orbi's maximum link speed on 5 GHz is 867 Mbps. You will only ever see throughput of 50% to 60% of the link speed under ideal conditions, due to the overhead involved in the WiFi protocol.
- RodGoldingNov 07, 2017Aspirant
So this is a limit in WiFi it self. Does it make any difference if the 2.5 GHZ is on or off. Also would it make any difference if I went back to my Nighthawk AC5300?
- st_shawNov 07, 2017Master
