RodGolding's avatar
RodGolding
Trying to get 1 gig out of my Orbi WiFi connection.
Just signed up with Comcast/Xfinity Gig service in the Houston area. I am using a Netgear CM1000 for a cable modem along with a Orbi RBK50/RBS50 system. The best I hve been able to get in WiFi is 350...
  • st_shaw's avatar
    st_shaw
    Nov 07, 2017
    Having the 2.4 GHz OFF makes no difference.
    WiFi is inherently limited to 50-60% of the link rate. So, yes you can get more throughput if you use a combination of router and client device that both support a higher link rate than Orbi's 867 Mbps.
    Orbi is designed for good coverage of a large area, not for peak speed for a single client connection.
    Your Nighthawk claims to support a link rate of 2166 Mbps.  This requires a client that supports 1024QAM modulation.  It's unlikely you have a client that supports that. If you did, you'd need to use it very close to the router to get that link rate.
