Philpilot
May 26, 2019Tutor
Trying to update Firmware on a RBS 50
Trying to update the firmware on my RBS 50. My router is now V2.3.1.60, the satellite is at V1.4.0.18 and will not update. trying to update to V2.2.1.212.img but it tells me that the formate is inco...
- May 27, 2019I worked out later last night, I kept going back in updates until I found an update would take. Thanks everyone for your help.
May 27, 2019Guru - Experienced User
v2.0.0.74 I found was the key to upgrading from v1x FW going forward.
- PhilpilotMay 27, 2019TutorI’m not at my computer at the moment, but it was the first V2.x.x.
- michaelkenwardMay 28, 2019Guru - Experienced User
Philpilot wrote:
I’m not at my computer at the moment, but it was the first V2.x.x.Thanks for the feedback.It might help someone who turns up with the same issue.
Sort of makes sense.
