gallen526
May 17, 2020Follower
Trying to update the firmware inn an RBR50 Orbi Router
Trying to update old firware in an Orbi RBR50. Firmware loaded is 1.4.0.18. Found the directions that you cannot update directely to the current firware, that you must update manually to 2.2.1.212....
tomschmidt
May 17, 2020Virtuoso
Make sure you extract the zip file and use the .img file for the firmware. The zip file is not the file to upload for the firmware.
