Awdandeker11
Dec 04, 2019Aspirant
Trying to use rbk20 WiFi system to get fast internet in garden office. Failing miserably..help!
So I have a garden office at the end of the garden that I’m desperate to get a quick connection. I have set up the rbk20 router to my virgin smart hub 3 in modem mode. Everything seems to be working o...
Awdandeker11
Hi thanks for the reply.
The router and satellite now have clear line of site between 2 windows approx 15metres apart.
Power for the office is from the house and have already tried a power line WiFi booster but my speeds were still very slow.
Firmware is v2.3.5.26...latest I believe.
Is having issue a with the satellite disconnecting intermittently.
Dec 04, 2019Guru - Experienced User
So what is your house materials. Line of sight doesn't tell me where everything is or necessarily explain the issue. You could have the router "in line of site" but far away from the window so only a small part of the spectrum is making it through your house window and then the garden window. This would cause intermittent connection/drops/slowed speeds.
When the orbi's default to 2.4ghz is usually means the 5ghz can't connect at all. This occurs either due to distance, wireless interference, or material interference.
- Awdandeker11Dec 04, 2019AspirantOk thanks sorry I wasn’t clear.
The router is right up against the window. I would say about 40cm away. Facing directly towards the garden office, which is where the satellite is located. The satellite is right up against the window pointing back at the router. By clear line a siight I meant they can basically see each other through 2 windows.- FURRYe38Dec 04, 2019Guru - Experienced User
Whats the distance between the house and this garden office? Feet?
The router is right up against the window. I would say about 40cm away. Facing directly towards the garden office, which is where the satellite is located. The satellite is right up against the window pointing back at the router. By clear line a siight I meant they can basically see each other through 2 windows.- Awdandeker11Dec 04, 2019Aspirant
50 feet
