Grethferth
Mar 31, 2020Initiate
Trying to use RBK50 instead of FIOS router
I am trying to setup an Orbi RBK50 in place of a Verizon FIOS router. I have a CAT6 cable run from the OTN port (which is enabled) from the FIOS main box. When plugged into the FIOS WAN router port I have a connection to the internet. When it is plugged into the Orbi it does not detect the internet.
I have tried to plug a laptop into the ONT port, which has not been able to connect to the internet also (which is using DHCP).
Is there anything addional needed from Verizon to enable the Orbi to connect?
Greth
Problem was solved. I had to put the old Verizon router back online and release the IP from the Fios routes admin console. Once that happened the Orbi could see the Internet.
One other thing that happened was the DNS IP's needed to be changed (auto populated by Verizon), as they also interfeared with the connection to the Internet. I just went with 1.1.1.1 and 1.0.0.1, which worked fine.
Greth
- Is there a way to "reboot" the ONT?
(Maybe the ONT has "learned" the MAC address of the FIOS router and is waiting for it to reappear?) - Maybe Call Verizon and ask them, "what the f**k?"
- GrethferthInitiate
Greth
Great to hear.
Please mark your thread and solved so others will know.
Enjoy. :smileywink:
Grethferth wrote:Problem was solved. I had to put the old Verizon router back online and release the IP from the Fios routes admin console. Once that happened the Orbi could see the Internet.
Greth
