CH360
Apr 25, 2021Follower
Trying to view port settings on an RBR50
So I spent an hour on product support with Ring today. Last week, our Ring doorbell stopped uploading video after a motion detection. We still get the notification for motion, but no video at all. ...
alokeprasad
Apr 27, 2021Mentor
I don't have a solution, but I can offer a sympathetic ear.
I'm having a heck of a time with one Ring Spotlight Cam creating unplayable videos. A factory reset of the Cam fixes the problem for a while, then it reappears.
I suspect bad Cam hardware or firmware. The factory reset reverts to older firmweare on the Cam .. until the buggy one is re-loaded.
- The problem appeared after working for months.
- Power-cycling the Cam does not fix the problem
- The device has good signal (RSSI -43).
- The Cam responds to events, turns on lights and takes snapshots on command
- Factory reset of the Cam fixes the problem temporarily, which then re-occurs in a few days
Keep at it and post to the Ring forum.
Rant: Any time the Ring tech support "fixes" the issue, even temporarily by asking the router and the entire home network to be reset, they declare victory and blame the Orbi. Even though other devices and other Ring cams are perfectly happy.:smileyfrustrated:
Aloke
CrimpOn
Apr 27, 2021Guru - Experienced User
Are the other Ring cams the same model? (with the same software?)
If so, is it convenient to swap their physical location?
- alokeprasadApr 27, 2021Mentor
I have 1 doorbell cam wirh connected power supply that works flawlessly.
I have 2 Spotlight Cams (battery), one of which has the problem. The problem moves with the cam. Thats why I'm convinced that it is a problem with that specific cam.
But, one of the troubleshooting step w the Ring tech support is to reboot the RBR50, which "fixes" the problem for a few days/hours. Ring tech supports points the finger to the Orbi and asks to open ports etc, which I refuse (the other Cam is fine, and the whole shebamg was fine for months. So why muck around with the Orbi settings now?).
