spizzi
Jan 27, 2019Tutor
Tunnelblick and comp-izo deprecation - Netgear VPN setup files to be updated by Netgear?
Hello,
Anybody else running Tunnelblick and receive the following error after installing Orbi's VPN setup files for NonWindows?
****************start******************
Warning: This VPN may...
bplanz
Jul 02, 2019Aspirant
I have the same issue
Running an R6400
Firmware: V1.0.1.46_1.0.32
Tunnelblick 3.7.9a (build 5321)
Error message attached
Thank you
Mayostard
Aug 22, 2019Initiate
I was also constantly getting this warning, then found a recommendation online that worked for me. Open the client.conf file you exported from the router and change "comp-lzo" to "compress lzo". Then you'll need to reimport that configuration into Tunnelblick. When I did that I stopped getting the warning and the connection still works as before. (Definitely back up client.conf before you edit it, in case something goes wrong.)
Hope that helps!
Orbi RBR50 | Firmware v2.3.5.30
