Modeck's avatar
Modeck
turn off 5gh on my cm1000
My smart plugs will not connect to my cm1000. How can I turn off the 5gh?
  • You're in luck!
    The CM1000 is a modem only device. It doesn't have wifi.
    so no need to worry about turning it off.
    Or you can tell us which router you have so we can best help you :)
    • Modeck's avatar
      Modeck
      My smart plugs won't work on 5gh it seems. I have the google nest (3 of them ) set up.
      • FURRYe38's avatar
        Guru
        Make contact with the mfr of your wifi router for help and information regarding connections with wifi devices.
        Good Luck.
