Gorlum_IL
Mar 03, 2019Aspirant
Turn off LEDs on RBK23
How I can rurn off leds on RBK23 satellites?
ekhalil
Mar 03, 2019Master
Which LED's? All ring LED's will light briefly during setup or after satellite connectivity's status change for few seconds and will then turn off, so in stable condition all ring LED's will be off.
Gorlum_IL
All leds. I have one satellite in my bedroom, and led on all night.
- ekhalilMar 03, 2019Master
There are two LED's on Orbi, please see below:
- Ring LED is off in normal operation mode, so you should have it off during night unless there are disturbances in the network. Do you have the Ring LED on at any time? Which color?
- Power LED is on as long power is on. You can turn it off only by powering off the node! :)
- Gorlum_ILMar 03, 2019AspirantI told about ring led. If it's possible to turn it off?
- Gorlum_ILMar 03, 2019AspirantLight blue or amber.
As I mentioned, The Ring LED is normally off, so you should have it off during night unless there are disturbances in the network.
If it turns blue or magenta often then you have instability in your network. If you use wireless backhaul then you need to check your radio network and improve the coverage between the router and satellite so the LED on the satellite will then always be off.
What is the distance between your router and satellite?
