SnorkyMN
Sep 26, 2022Aspirant
Turn off WiFi on RBR50
Hello, Due to a new internet provider for my community, which is putting in WiFi in every unit, I don't need to use my Orbi anymore for Wifi, but I still want to use it as a switch/hub for my har...
SnorkyMN
They have to build a mesh, using the Amazon Eero, so my Orbi Mesh is no longer needed. And I didn't want the 2 additional wifi signals so close to where my wife and I are working. But if I can't figure it out, I'll just have to try to sell the base and Satellite and use switch.
CrimpOn
Sep 26, 2022Guru - Experienced User
Might be a good idea to "wait and see" how this plan to mesh a lot of units with eero works out.
The more paranoid of us would be a bit wary of sharing a network with LOTS of strangers.
- SnorkyMNSep 26, 2022Aspirant
Oh, the mesh would only be for in my home, I will not share a mesh with others. Though once outside our own personal networks, we're all on the same wire, just like for cable or whatever else.
- CrimpOnSep 26, 2022Guru - Experienced User
This appears to put you in the usual position, i.e. deciding which is more useful to you:
- The WiFi network provided by the Internet Service Provider, which it also appears that you are forced to pay for, or
- Your own WiFi network.
Maybe you will like the eero mesh system features and performance and prefer it, so the Orbi will be redundant and purchasing an inexpensive Ethernet switch to add enough ports to connected everything will be the solution.
Or, it could be that the eero is a disappointment and you are stuck with trying to get out of paying for it.
Looks like a "head to head" comparison is coming up. If the eero is given the exact same WiFi credentials (SSID/password), then you should be able to swap them back and forth to your heart's content.
p.s. Totally disabling the Orbi radios is impossible (for most of us who are not hackers), but the Transmit power level can be reduced to 25% and it will create minimal radio traffic since nothing will be connected to it. (once the WiFi SSID is changed).
Would love to hear how the experiment works out.
