Shaqz
Dec 03, 2022Aspirant
Turn RBR20 to a satellite
Is it possible to change the RBR20 to a sattelite. If flash it and install the RBS20 firmware. Will it work as a satellite?
1 Reply
Shaqz wrote:
Is it possible to change the RBR20 to a satellite. If flash it and install the RBS20 firmware. Will it work as a satellite?
No. There is a hack on the internet which converts an RBR50 into an RBS50. Have seen posts claiming that it worked. No one has ever posted hacking any other model.
