darinbrown's avatar
darinbrown
Turning off 5GHz remotely for RBR40
Hi all... i am trying to turn off the 5GHz to connect a 2.4GHz device (well have a friend do it).  I am not there (it's at my holiday home).  I've read that i can do it via advanced settings but I assume to be able to use the advanced settings i need to be local and use orbilogin.net.
is there a way to do this through the app or remotely?  it's too complicated for my friend.
  • FURRYe38's avatar
    Remotely possible if you have Remote Management enabled on the RBR and know the WAN IP address that the RBR is using on the WAN port. You'll need a web browser to access the remote side of the RBR. Can't be done using the Orbi app.
    • darinbrown's avatar
      darinbrown
      I do have remote management set up and i see an IP address in the router settings in the settings part of the mobile app.
      what steps should i follow?
      i thought i needed to be on the wifi locally to be able to get to the WAN IP address through a browser
      • FURRYe38's avatar
        If your remotely tryin to connect the the Orbi system, you'll need to find the WAN IP address which will be seen on the RBRs web page, under Advanced Tab in the Internet section list or the WAN IP address and port number should be displayed on the remote management section of the RBRs web page. Use this https://WAN IP Address:port#### in a web browser at your location to access the remote RBRs web page.
        If your not at the location physically, have someone log into the RBRs web page to get this information for you.
