ChiffaNe
Mar 24, 2023Tutor
Turning on VPN access to Orbi remotely
I have the following situation: I had an old Orbi RBR50 set up back in my home country with DDNS and VPN enabled and configured, allowing me to connect to my home network from wherever. After ...
CrimpOn
Mar 24, 2023Guru - Experienced User
Internet port.If OpenVPN was running on the old Orbi, it should still be enabled. If you can determine the current public IP address of the old Orbi router*, you could edit the OpenVPN client configuration file to use the actual IP address rather than the DDNS name. After connecting, you could modify the DDNS entry on the old Orbi so that changes in the public IP address will be tracked.
* Actually, if the Orbi 'app' still connects to the old Orbi, then the public IP address can be found on the Router Settings,, Details page
- ChiffaNeMar 24, 2023Tutor
I tried this already and the connection is not getting established so my assumption is that the VPN got turned off automatically.
- CrimpOnMar 24, 2023Guru - Experienced User
Oh, geez. I would not expect the Orbi to spontaneously disable OpenVPN. Mine has persisted through several firmware updates. Is there someone who can access the Orbi web interface locally to bring up the OpenVPN page and see if is remains enabled?
I am trying to organize that and all those guys don’t have a clue on IT, so it will be fun trying to explain this over the phone. If I can get someone there I can have them just register a new ddns name and then turn it back on, so that’s not an issue. Will take a while though so I’m trying to see if I can manage myself, I still have the app access, maybe there is a hidden advanced mode there or smth.
and wrt to persisting - yeah it persists over upgrades and stuff, but I seem to remember setting up DDNS is a prerequisite to enable OpenVPN, so kinda makes sense it’s turned off when I disabled DDNS.
