Ducroo
Aug 12, 2017Aspirant
TV box needs direct internet access - can I still use netgear orbi in between?
Hi, I have an netgear Orbi router and a TV box. As I only have a single RJ45 internet connection cable (long story), I would like to connect the Orbi to that and the TV box to the orbi. However, ...
peteytesting
Aug 12, 2017Hero
what you are after is vlan/bridge settings
check the advanced section of the gui and advanced setup , the vlan may be there however i dont really know how to set it up yet
if its not in the firmware you have atm it will be soon
