Charleyo
Jul 03, 2019Aspirant
TV Streaming with FIOS
I have the rbk20 with one satellite. My Home is ~2000 sq ft. Router is on first floor and satellite is on 2nd floor. My question is why can I stream tv using my fios router but when I use orbi it ...
Jul 03, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 or #3.
- CharleyoJul 04, 2019Aspirant
Thanks for the help. I used #3 and it seemed to work last night. However my satellite shows amber so I need to either move it closer to the router or get one more satellite.
- michaelkenwardJul 04, 2019Guru - Experienced User
With the Orbi in AP mode you do not need to disable the wifi. Just be careful about what devices connect to.
Without more information about your network, it is hard to interpret what is going on there.
Have you tried using the satellite as it is?
The lights may be useful to see what is going on, but the real measure of things is to actually use the network and see what happens.
I have the Fios Quantum Gateway Router in a two story home with concrete walls on the bottom floor where the Gateway and Orbi routers are located. Main floor is where the bedrooms and living room are located. Since the current satellite shows amber but works should I get an additional satellite to place between current router and satellite? If I would have purchased the rbk50 I would be fine but I went cheap and got the rbk20. I just don't want to waste money for no benefit. I could also move the Orbi router to the main floor. I'll try a couple of things before I purchase another satellite. Appreciate everyone's help.
- FURRYe38Jul 04, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
IF your connecting the RBS via ethernet at any point, ensure Diaisy Chain is disabled on the RBR and the RBS is directly connected to the RBR, no the FIOS router.
Charleyo wrote:Thanks for the help. I used #3 and it seemed to work last night. However my satellite shows amber so I need to either move it closer to the router or get one more satellite.
