Charleyo
Jul 03, 2019Aspirant
TV Streaming with FIOS
I have the rbk20 with one satellite. My Home is ~2000 sq ft. Router is on first floor and satellite is on 2nd floor. My question is why can I stream tv using my fios router but when I use orbi it ...
Charleyo
Jul 04, 2019Aspirant
Thanks for the help. I used #3 and it seemed to work last night. However my satellite shows amber so I need to either move it closer to the router or get one more satellite.
michaelkenward
Jul 04, 2019Guru - Experienced User
With the Orbi in AP mode you do not need to disable the wifi. Just be careful about what devices connect to.
Without more information about your network, it is hard to interpret what is going on there.
Have you tried using the satellite as it is?
The lights may be useful to see what is going on, but the real measure of things is to actually use the network and see what happens.
