ramair02
Feb 17, 2021Aspirant
Tweaks for better wireless performance of Rokus?
Hey. So, I'm not sure if this is an Orbi issue and if there are some settings I can change to improve performance, but I'm having some issues. My setup is RBK50 (RBR50 + RBS50) and FiOS gigabit conne...
CrimpOn
Feb 17, 2021Guru - Experienced User
Do the Roku's report which frequenc band they are using?
What 5G channel is the Orbi set to? (on mine, the choices are 36, 40, 44, and 48)
ramair02
Roku is on 5ghz frequency band. Orbi is set to channel 48. I tried some different channels today. It was on 36 before. No improvement in speeds down on the Roku. The basement Roku TV is 10 feet from the router.
- alokeprasadFeb 17, 2021Mentor
Any way to connect the Roku to the Orbi router via an ethernet cable (for testing)?
If that works fine, then you know that the performance issues are because of WiFi.
- CrimpOnFeb 17, 2021Guru - Experienced User
My adventure continues. Now have Roku Ultra. Roku reports "Excellent" WiFi connection, with 37mb internet download speed.
At the same time, a Samsung tablet reports wildly different Ookla speeds depending on (a) orientation (vertical, horizontal), and (b) placement. Moved it two feet and the speed changed from 44mb to 160mb.
Will do much more testing tomorrow. For now, I wonder if (a) Roku's speed measurement is not consistent with Ookla to begin with, and (b) how sensitive Roku performance is to physical placement. (with a six foot HDMI cable, my options are limited).
- ramair02Feb 17, 2021Aspirant
CrimpOn wrote:My adventure continues. Now have Roku Ultra. Roku reports "Excellent" WiFi connection, with 37mb internet download speed.
Ah! Interested to hear about your findings. I'd be so suprised if physical placement is a big factor, but you may be on to something. My phone Ookla is pretty consistent, but more importantly my basement roku tv is 10 feet from the router, so it must have amazing signal.Roku's speed measurement may be off, but I can comfortably stream a 20mbps bitrate movie, but I struggle with anything higher bitrate than that (likely due to spikes in the bitrate). And that makes sense to me with speeds wifi of 30-50mbps across my rokus.
alokeprasad wrote:Any way to connect the Roku to the Orbi router via an ethernet cable (for testing)?
I hooked up an ethernet cable. Wired is 85mbps down.- alokeprasadFeb 18, 2021Mentor
I hooked up an ethernet cable. Wired is 85mbps down.A wired connection to the router is the BEST performing connection you can get.
See what speeds you get on a laptop connected to the ethernet and compare that to the 85 mbps you are getting from the Roku.
If the Roku is slower, it is the way Roku measures the bandwidth.
