motiwalla
May 12, 2020Aspirant
Two devices with same IP address - how to resolve?
Hi I have two attached devices which share the same IP address: 168.192.1.12. One is Orbi Satellite router and another is a backup drive. I tried to change or delete the IP but there is NO opti...
May 12, 2020Guru - Experienced User
What model Orbi do you have? CBK40?
What is the IP address the Lacie device is using?
Have you gone to the Mfrs support site to see if they have the sofware needed?
You might factory reset the Orbi system and RBS. Then power OFF the RBS. Setup the RBR only and get it setup. Power on our Lacie device. Then power ON The RBS then add it. The RBS should get a new and different IP address. Set a IP address reservation for the RBS on the Orbi router using a PC or laptop and a web browser.
motiwalla wrote:Hi
I have two attached devices which share the same IP address: 168.192.1.12. One is Orbi Satellite router and another is a backup drive. I tried to change or delete the IP but there is NO option for changing IP. The backup device IP comes from OLD lacie hardrive and I don't have any software to change from the device.
IF I cannot EDIT/Delete from ORBI app, Is it possible to give Orbi Satellite a Static IP? If so, please let me know HOW.
Thanks
..LM
