7401Question's avatar
7401Question
Follower
May 09, 2022
two factor authentication
I have an Orbi Wifi router. I am using 2FA for the mobile devices that I use to manage the system, but is there a way to establish 2FA when a new device attempts WIFI access to the router?  The password helps against intruders joining my Wifi network, but I'd like to receive notification when somebody tries to join.
Thanks.
1 Reply
  • CrimpOn's avatar
    CrimpOn
    I am not aware of any residential WiFi router supporting 2FA for the WiFi connection.
    The underlying WiFi technology does not have that methodology (WPA2, WPA3, etc.) Either the device supplies the correct (complicated, hard to guess) password, or it doesn't.
    The Advanced security feature Access Control has a setting to "Block new devices from connecting"
    In this case, the "second factor" (after the password) is that the owner has to specifically allow the device. (not what you are wanting)
    There is a huge difference between authentication and notification.  I have not enabled Armor or Parental Controls on my Orbi, but I read here that Armor does something similar to what you want:
    https://www.bitdefender.com/consumer/support/answer/28378/
    (Whether it works or not, I have no idea.)
