Kerry_Reynolds
Jan 23, 2020Follower
Two Orbi Network - 1 modem
Hi I live in a sprawling apartment block of multiple buildings. I have had the Orbi RBR50 router and 2 satellites working very nicely for a couple of years now. My landlord was so impressed with my ...
Jan 23, 2020Guru - Experienced User
Are you piggy backing off this modem? Most modems only support 1 external router behind the modem. Unless it's a gateway modem with a built in router, then you could possibly connect your RBR to this gateway, input the IP address your RBR gets from this gateway into it's DMZ and run your RBR50 as a router. Otherwise, you may have to run your system in AP mode behind his RBR850.
