haolik
Jan 02, 2021Follower
Two Orbi routers in the same Orbi network
Hello! I have an older Orbi RBK 50 router and a satellite from autumn 2018 and now I bought a bit newer RBK 50 router and a satellite. I tried to study how to use another router in AP mode connected ...
vajim
Jan 02, 2021Master
I believe your problem is related to your misunderstanding of how networks are extended
Even if you were able to make the 2 routers work (and I'm sure others in here will guide you to a solution) using 2 routers may not be any better than how the satellites work with router itself
Good luck
