andrezanin
Oct 22, 2020Aspirant
Two RBR20 routers to form a MESH network
I have 2 RBR20 routers and I want to set up a Mesh network, but I'm not getting it, one of them works as a satellite? Can I synchronize the 2 RBR20 devices on a wireless mesh network?
Oct 22, 2020Guru - Experienced User
Officially there isn't.
Unofficially there's a way to do it but it requires quite a bit of effort and risk of bricking your router. So you probably won't find it on the official forum.
- andrezaninOct 22, 2020Aspirant
Thank you very much, So I can't make a Mesh network with 2 RBR20 routers via cable or wireless, officially? So it would be useless to form Mesh network?
Does this model use Circle 1st generation parental control only? Wouldn't it be compatible with the second generation?- plemansOct 22, 2020Guru - Experienced User
andrezanin wrote:Thank you very much, So I can't make a Mesh network with 2 RBR20 routers via cable or wireless, officially? So it would be useless to form Mesh network? Potentially you could use one as router and put the other in access point mode. You'd just want to use seperate ssid's on them. Or use google/reddit a little to find the procedure to switch one to a satellite.
