Warren123
Mar 05, 2019Follower
Two wireless networks networks
I have two smart televisions in the house. The newer one (like all my other devices) is showing my one wireless network name.
The older television is showing two the networks names. One with 5g pho and the other with 2.4 ghz
is there a reason for this. Is it because it’s an older television. I thought the unit was suppose to automatically choose the better ghz?
Chuck_M wrote:
Your TV is just showing available networks... the older TV doesnt realize the same SSID on both networks are the same.
Correct Chuck_M , there are devices that look for the MAC address of the network's AP and not only the SSID. So if you have a Router and a Satellite you will see 4 networks two from the router (2.4 and 5 GHz) and two from the satellite (2.4 and 5 GHz) because each of these networks has a unique MAC address.
It maybe that the older TV FW can show two different SSID names between the two frequencies even though the Orbi is broadcasting just the one SSID, the TV is separating them based on the two frequencies. Have you updated the FW on the TVs?
- Chuck_MMentor
When you configure those TVs you will have to pick the appropriate band and SSID, but this isnt anything other than an older Television firmware. Has zero to do with Orbi.
- ekhalilMaster
Better signal is more important than "better" GHz. 2.4 GHz has a longer range than 5 GHz. Less likely to fall over if the signal fades.
A TV will work find with 2.4 GHz. It is only recently that they started using 5 GHz.
