GWild
Feb 16, 2021Guide
Typical Speedtest Result Expectations for CBK40 Kit
Anyone have FIRSTHAND knowlege of the actual throughput for a CBR40 - RBS20 via wifi? CPU - 1GbT (wired) - RBS20 ~~~ BACKHAUL ~~~ CBR40 - 1Gb CABLE It's essentially using the RBS20 as a bridg...
- Feb 20, 2021
Heres what I get with my wired PC connected to a ASUS GT-AX11000 in wireless bridge mode connected to my Orbi 850 series connected to a CM1200 modem:
This is about max speed I generally see with most any of my 1Gb LAN devices.
GWild
Feb 19, 2021Guide
Considering the AX4200 solution: CBK752. If I read the specs right it says back haul is 2.4Gb, leaving 1.2Gb and 600Mb for other devices. Should be adequate to allow 1Gb wireless down traffic. But, have a doubt based on the CBK40 experience - will the modem really do that 6Gb/s they claim. The application would be replacing the CBK40, the RBS connects to a 10G engineering network and bridges to the CBR a room away. Wire wasn't really an option - but - it might be worth it at this point, $600 is steep for a few extra Mb/s I don't really need).
FURRYe38 wrote:I had to take a quick look as well. I hadn't noticed that Ookla reported sparklight back then. I to remember seeing cable one back then.
I see that SL has the CBK40 on there 1Gb plan. Interesting it's at the bottom of the list:
Well if SL is seeing some issues. I'd keep on them. Other than this, you'll need to contact NG support and let them know what your seeing. I have long since moved from the CBK40 to now CM1200 and Orbi AX. Mostly over 900Mpbs when testing.
Waving a had accross the valley.
Feb 20, 2021Guru - Experienced User
