jdstephe
Dec 11, 2020Tutor
UK/US Compatability RBS50
Hi all, does anyone know if a UK RBS50 woud connect and be compatible with a US RBR50 and RBS50? I recently returned to the UK after living in the USA where I purchased and RBR50/RBS50. I would lik...
Dec 11, 2020Guru - Experienced User
Don't know for sure. In most cases I presume they should IF the firmware loaded on the RBS is the same as loaded on the host RBR...Can't say much more than this...
