jdstephe
Dec 11, 2020Tutor
UK/US Compatability RBS50
Hi all, does anyone know if a UK RBS50 woud connect and be compatible with a US RBR50 and RBS50? I recently returned to the UK after living in the USA where I purchased and RBR50/RBS50. I would lik...
CrimpOn
Dec 11, 2020Guru - Experienced User
jdstephe wrote:Hi all, does anyone know if a UK RBS50 woud connect and be compatible with a US RBR50 and RBS50?
I would like to add an extra RBS50 satellite to my system, but wasn;t sure if there would be any connectivity issues.
The old system is working flawlessly in my new home here, despite the firmward seemingly "locked" to a US region.
Will work. By the way, there are some differences in WiFi regulations which make it a good idea to change the Region setting.
Here is a post about how to do that:
https://community.netgear.com/t5/Orbi/Orbi-RKB53-global-differences/m-p/1736104#M59059
