MartijnS's avatar
Oct 22, 2021
Ultraslow Wifi
Hello
I have the following setup
ISP router (Ziggo) -> SRR60 as AP -> 5x SRK60 (3x wired, 2x wifi) and 1x SRC60 (wifi) -> wifi and utp clients
                              -> unmanged switch -> utp clients
The base speed is 600mbps
The wired clients get this speed
The wifi clients sometimes do okay with 200mbps but for no apparent reason can do max 10mbps the next day (same situation)
I tried:
splitting networks, no luck
splitting 2.4 and 5 Ghz, no luck
The mesh status is excellent on the wired ones and good on the wifi ones
What could cause this or what can I try?
1 Reply
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Orbi Pro products. Most of the people who watch that forum are more likely to have experience with Orbi Pro and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifi
    Thank you.
