JDBAIN's avatar
JDBAIN
Unable to Access Device Manager to switch to 2.4 GHz
When I go into the Netgear website, it longer allows me into the Device Manager.  The app does show the devices but is limited. For some reason, one night last week, it appeared briefly but now I cannot access it using the same URL.  I'm simply trying to allow a IoT device to connect using the 2.4 GHz as the ORBI router runs both 2.4 and 5.  My knowledge of IT is very limited.  But this was somewhat easier when the Device Manager appeared in the Netgear website. Any suggestions are appreciated.  I've gone down the rabbit hole of reading other posts which seems to be an endless copy and paste of other posts.
  • CrimpOn's avatar
    CrimpOn
    The vast majority of Internet of Things (IoT) devices connet to the Orbi without any extra effort.  That warning in BIG TYPE, "Must have 2.4G WiFi" is simply stating a fact.  No 2.4G WiFi means it cannot connect.  The device has only a 2.4G radio chip.  That is like saying, "Takes 2 AA batteries."  No AA batteries?  Device cannot work.  You can have all the C cells, D cells, AAA's in the world.  No AA's means it can't work.
    Orbi provides a 2.4G WiFi and 99% of the devices I have tried to connect simply connect using the smartphone app.
    Can you share which specific device this is?
    Did you ignore the warning and plunge ahead with the smartphone app?
    Where did the process fail?
    On the specific Orbi that you have, there IS an option on the web interface (http://orbilogin.net) on the Advanced Tab, Advanced Settings (bottom menu item), Advanced Wireless Settings to "Enable/disable SSID Broadcast" on the 5G WiFi.  Some users have found that they can turn off the SSID broadcast. "Forget" the Orbi WiFi on their smartphone.  Reconnect the phone and then connect their IoT device.
    • JDBAIN's avatar
      JDBAIN
      Appreciate the quick reply.  And thanks for sharing the website.  That is exactly what I was looking for. I had it saved but it kept sending me to the netgear page without any link to the device manager.
      The device is Orbi 153.
      As for the app, I'm unsure what warning you're referring to. Perhaps you're referring to the notification about 2.4 GHz in the app for the lights?   When I irst used the app, it did state that the lights did to use 2.4 GHz.  I knew the router was set for both 5 and 2.4. My expectation is that it would link in to the 2.4 as a priority.  I have had to spend several minutes (i.e., hours) trying to connect each light to the wifi.
      Out of 3 lights I have, 1 I could never get connected, even when I brought the ORBI satellite to within a few feet. The other two dro intermittently. Then I need to go back and spend several minutes trying to get them reconnected. It's maddending.
      I can try the SSID below.
