Anonymous's avatar
Anonymous
Mar 25, 2018
Unable to access internet after connecting to VPN
So I occasionally work from home and connect to my company's VPN and then remote in to my work PC.  When I'm on my home network, I can successfully connect to the VPN but then I am unable to access t...
  • Anonymous's avatar
    Anonymous
    Jul 14, 2018
    I finally figured out what the problem was.  On my chromebook I had the "Prefer this network" setting enabled for my Orbi's wifi network.  Once I disabled that option, everything started working fine.  :smileymad:
