Retired_Member
Mar 25, 2018Unable to access internet after connecting to VPN
So I occasionally work from home and connect to my company's VPN and then remote in to my work PC. When I'm on my home network, I can successfully connect to the VPN but then I am unable to access t...
- Retired_MemberJul 14, 2018
I finally figured out what the problem was. On my chromebook I had the "Prefer this network" setting enabled for my Orbi's wifi network. Once I disabled that option, everything started working fine. :smileymad:
guzzijason
Mar 25, 2018Apprentice
Is the Orbi connected to a router or a bridge? And is the Orbi in router or bridge (AP) mode itself?
- Retired_MemberMar 25, 2018
The Orbi is in router mode, and is connected to my cable modem.
