chantrybee
Mar 14, 2024Aspirant
Unable to access my home battery's IP address (172.16.XXX.YY)
Hi, I have two Sonnenbatteries. I used to be able to access the configuration/admin website by going to an IP address 172.16.XXX.YY. I have changed my Orbi (RBR50 and two RBS50 satellites) settings ...
chantrybee
So, the LAN cables from the batteries go into a mini switch which is then attached to a Hive hub. In my devices I can see the Hive hub, but not the batteries connecting into it…
Mar 14, 2024Guru - Experienced User
are you able to log into the hive hub and see whats attached?
