tucsontico
Jan 11, 2017Virtuoso
Unable to access Orbi Satellite via Web Browser
I recently installed the ORBI (with one satellite) in place of a R7000 Nighthawk. I am running all on a Mac OS environment and the latest ORBI firmware (V1.0.4.34) with essentially minor glitches. Ho...
- Jan 16, 2017
After a lot of power cycles, reboots, etc. I finally may have discovered the problem! I tried simply moving the satellite a little closer to the router. Guess what? Miraculously, I began to "see" the satellite webpage (192.168.1.2) and was able to view devices attached to the satellite!
I only moved the satellite about 15 feet closer and let it re-connect to the router. I am now able to view all the information about the satellite via it's web page. However, the WiFi signal in an area I originally purchased the ORBI to cover is very weak.:smileysad: The satellite originally had a "blue" light in the first location but I'll bet it went "amber" soemtime after I installed it. It now has a solid "blue" connection and appears to be working.
A note for NETGEAR: please fix the firmware so even in an "Amber" connection state the satellite will respond to queries from the web-based GUI.
loomis1975
Jan 11, 2017Luminary
Does the satellite at 192.168.1.2 show up on the router's attached devices page?
- tucsonticoJan 11, 2017Virtuoso
Yes. It shows on the router's list of attached devices at 192.168.1.2
- peteytestingJan 11, 2017Hero
reboot the orbi system / power cycle all orbi units and do the same for all your devices , see if that helps
- tucsonticoJan 12, 2017Virtuoso
Please note that in my initial post I stated I had already tried rebooting, power cycling and even reloading the firmware. Unfortunately that didn't help the issue. The most frustrating thing about it is, when devices are connected to the satellite, they simply dissappear from the router's attached devices list yet are obviously connected to the intenet!
Additionally, when I checked the ORBI router this morning via the web browser GUI, I noted that the satellite had changed IP addresses (192.168.1.250) even though I "reserved" 192.168.1.2 for it. Even more odd is I had set the IP address range to stop at 192.168.1.100! This is getting really weird!
