nadnoteri55
Aug 03, 2020Aspirant
Unable to access orbi via browser or app
When I try to access the orbilogin, it says "Looks like you’re not connected to your Orbi’s WiFi network." When I try to access it via the orbi app, it says its unable to detect the orbi. I'm on th...
Mstrbig
Aug 03, 2020Master
Did this issue just start? If so have you changed anything, or updated firmware, etc.? Are you conneted to the WIFI of your Orbi?
nadnoteri55
About a week ago. No changes or tweaks to anything. I've restarted it a few times to try and get it to show up "detect" , but it will start for a little bit then stop seeing it. Past couple times trying to do that has resulted in it not being found at all.
No issues with internet access or quality though. That is why this is so weird. And yes, I'm on the wifi network of the Orbi.
