Hendy
Jul 18, 2020Follower
Unable to access RBR20 with app or Browser
Im hoping someone can help I've had this router for about 6 month now and I've had the following issues. 1. disconnected or dropped wifi signal. 2. Over the last two days I have not been able t...
Jul 18, 2020Guru - Experienced User
Press the back reset button for 15 seconds then release. Walk thru the setup wizard with a wired PC or laptop connected to the back of the RBR. Try using a different browser, IE11, FireFox or Opera. Clear ALL browser caches. Find the wizard at 192.168.1.1
Something to configure after the RBR is set up...
