UP4278
Dec 29, 2020Aspirant
Unable to access the admin page after firmware update
Orbi RBR20 - After applying the most recent version of the firmware (2.6.1.36), my admin credential doesn't work. I went through input the router serial#. Then it asked input for 2 security questions...
UP4278
Dec 30, 2020Aspirant
100% certain. I used the correct admin password. (not entirely sure about the security questions).
Now it is a mess I needed to reinstall the entire thing. :(
Dec 30, 2020Guru - Experienced User
Let us know how the reset goes. After setting up from scratch be sure to save off a backup of the configuration to file for safe keeping. Saves time if a reset is needed.
UP4278 wrote:100% certain. I used the correct admin password. (not entirely sure about the security questions).
- UP4278Jan 02, 2021Aspirant
After the factory reset everything is back fine. All Circle settings were lost (annoying)..
I will not buy another Netgear device.
- fmalloyJan 02, 2021Luminary
UP4278 wrote:After the factory reset everything is back fine. All Circle settings were lost (annoying)..
Advice around here seems to be a "factory reset" for so many issues. To me, forcing your device to be factory reset is an indication of poor design or firmware bugs.
A factory reset should need to be done only twice - at the factory, and when you sell it.
- FURRYe38Jan 02, 2021Guru - Experienced User
To avoid settings being lost, the backup configuration to file is a feature that users can use to save a configuration to file. So after a reset is needed, you can reload the configuration from file and get your settings back.
Resets with ANY mfr router will clear out ANY user configurations. Nature of the beast and is a normal troubleshooting step.
Good Luck.
