UP4278
Dec 29, 2020Aspirant
Unable to access the admin page after firmware update
Orbi RBR20 - After applying the most recent version of the firmware (2.6.1.36), my admin credential doesn't work. I went through input the router serial#. Then it asked input for 2 security questions...
Dec 30, 2020Guru - Experienced User
Let us know how the reset goes. After setting up from scratch be sure to save off a backup of the configuration to file for safe keeping. Saves time if a reset is needed.
UP4278 wrote:100% certain. I used the correct admin password. (not entirely sure about the security questions).
Now it is a mess I needed to reinstall the entire thing. :(
UP4278
Jan 02, 2021Aspirant
After the factory reset everything is back fine. All Circle settings were lost (annoying)..
I will not buy another Netgear device.
