S_anand
Apr 08, 2020Follower
Unable to access websites while connected to Orbi wifi network
Orbi model: RBR50 While connected to the Orbi wifi network, many websites are blocked that are accessible if I connect to my AT&T modem wifi network directly.
Apr 08, 2020Guru - Experienced User
Built in router here by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
