ygarti
Jun 12, 2019Aspirant
Unable to Change DNS
Hi All, i would like to change my dns to a difrent dns (i don't want the orbi to be my dns server) but no matter what i am doing i am always getting dns server = 10.0.0.1 (my orbi) but wh...
schumaku
Jun 12, 2019Guru - Experienced User
ygarti wrote:i am prety sure it's a FW bug and i don't know how to bypass it ( i would like to use pihole and i can;t becuse of that)
I`m pretty sure it's not a bug - much more lack of understanding on how a NAT router works.
ygarti wrote:but when i am looking in the dns under internet port i see that my dns is 1.1.1.1 (cloudfire dns)
The router can be configured to run it's queries either to the ISP supplied or custom supplied DNS IP addresses - that's what you can configure on the Internet settings. Unless you want to point the router DNS to a LAN IP address - the Netgear routers don't allow this why ever - that's OK in general.
ygarti wrote:but no matter what i am doing i am always getting dns server = 10.0.0.1 (my orbi)
but if i am looking in the client side i still see 10.0.0.1 and i have no idea how to change it
Your "getting" and "looking" seems to be based on what the router DHCP server does provide along with the host IP config. The Netgear routers automatically supply the router LAN IP address. This is done because of the Netgear routers run a DNS relay, implemented by a (poorly configured, very cheepo configured) dnsmasq. Here again, the Netgear consumer routers don't have an option to change this configuration. In Netgear's heads, consumers don't run DNS local servers, don't need local DNS services, ...
The only workaround would be to run DHCP server _and_ DNS server - disabling the DHCP server should be possible on Orbi, it certainly is on the Nighthawk routers.
PS. People deploying Pi-hole and the likes must be aware that they are destroying the business model for many otherwise "free" services - hosting, bandwidth, systems maintenance, support, and even providing content does cost money - without income from ads, this is the end for many services.
ygarti
first thank you for you answer and your time
1. i don't think it's a bug i think they are doing it on purpose so they can see my dns traffic and sell it (there isn't realy any other reason to do it let along not giving the option to disable it).
2. i know i can use a diffrent DHCP server but i don't want to do i don't understand why this basic option is not exist in this very expensive router.
