Evp58
Jul 20, 2023Tutor
Unable to change password on RBR40
I have had my network using Orbi router and satellites for several years now. I need to change the Guest Network Password. I tried several times - it tries and comes back "unable to update" What...
- Aug 08, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Evp58
Jul 21, 2023Tutor
Thanks for your detailed reply!
I am always up to date on the RBR40 software. Checked before I sent this message. I had been doing setup on my iPhone as I have always done.
I have been using a Netgear modem for several years.
Nothing new - I simply wanted to change my Guest Network password as it was recommended by my Bitdefender security. Also, I noticed some strange devices on my Guest Network. I shut off the Guest Network and then turned it on again. Bidefender says I am using the "default password", whatever that is. But I had been using my own password.
I am hesitant to reset the entire system again as I have some 35 devices on the network and it is a tedious task to go to each one to update the latest password! For example, I have about 12 Nest Thermostats - each one has to be logged in at the thermostat.
Jul 21, 2023Guru - Experienced User
If you factory reset and setup from scratch and use same SSID name and PW for the wifi, your devices will auto reconnect.
- Evp58Jul 21, 2023TutorThank you! I will try later and get back to you!
- Evp58Aug 08, 2023Tutor
I finally solved the problem. I logged into Orbi from my Safari browser on my iMac and was able to assign a password to my Guest Network! Didn't have to do anything else!
Thanks to all for your suggestons
- FURRYe38Aug 08, 2023Guru - Experienced User
Enjoy. 📡
