clo2471
Dec 09, 2018Aspirant
Unable to complete Amazon Alexa set up in Orbi App for RBS40V Orbi Voice
Hello!
I recently purchased Orbi Voice RBS40V to add to my existing Orbi AC2200 Tri-Band Mesh Wi-Fi System with 32x8 DOCSIS 3.0 Modem. I was able to add the Orbi Voice as a satellite, but when...
Bismarck18
Dec 10, 2018Aspirant
Having the exact same issue on a newly purchased Orbi voice. Running the support gauntlet currently. Awaiting a call back from Tier 2 support. Firmware is up to date. Deleted and reinstalled the app. Nothing works. Will let you know how it turns out when/if they call me back.
clo2471
Dec 13, 2018Aspirant
Thanks for the response! Hope you get an answer. Please share if they do get back to you.
- Bismarck18Dec 14, 2018Aspirant
Hello again. I was able to get this working but it required a firmware update to the router (Model CBR40). Support indicates there's a new firmware version that should be release din the next day or two for the router which resolves the issue of being unable to access the Orbi Voice to configure Alexa via the app. You can contact support and ask for the beta firmware if you'd rather not wait. Hope this helps.
