Cemad
Feb 03, 2021Aspirant
Unable to connect HVAC Wi-Fi
I have a Orbi hole home router. I am not really Tech savvy. I recently had a new HVAC system installed that has Wi-Fi capabilities. For some reason , I am having trouble connecting the system to the ...
CrimpOn
Feb 03, 2021Guru - Experienced User
Cemad wrote:If I push the reset button on the back of the router, will it delete other equipment that's already connected?
Doing a Factory Reset will return the router to the condition it was in when it came from the factory. Anything that was done to configure it will be erased. If it was taken out of the box, plugged in, and used "just like it was", then everything that was connected using the WiFi credentials on the product label will reconnect automatically.
What is the brand of HVAC you are trying to connect?
