HunterK
May 28, 2017Tutor
Unable to Connect on Mac Devices
We have been loving the Orbi with very few issues. All of a sudden today we could not connect to the internet with any mac computer. All of our mobile devices worked fine as well as a windows laptop....
- May 29, 2017Okay so we kind of fixed it. From what I could find there was an update that went out a few days ago and I think that was the culprit. Unfortunately you can't un-update so the fix is not that easy. I called tech support and we got it to a point where it mostly works, not as flawlessly but it does. I don't know how personalized the fix is but it requires a good bit of stuff. All of these changes were done on the orbilogin.com bit.
The first thing we changed (that didn't end up working) was under Basic->wireless settings->something to do with DSN we changed it from getting it automatically to a specified set of numbers that went like this:
8.8.8.8
4.2.2.2
4.2.2.3
I don't know how much of this was solely for my router but that's what we did.
The next thing was under Advanced->Advanced Setup->Wireless Settings go to the last two options and have those checked. I can't remember what the settings were called and I am unable to get there for a few days because I'm out of town so if somebody else has it that would help.
Lastly in the same area we went to the 5.0 ghz settings and unchecked something to do with wifi and radio waves or something that effectively turned off the 5.0 ghz band, which made the whole thing work better.
Keep in mind at this point you should restart your router and computers so that everything takes effect and it should work.
I would recommend just calling tech support because I'm not very helpful in explaining it, but this is what worked for me and you can try that.
HunterK
May 29, 2017Tutor
I can't seem to even downgrade the update. I get the previous file and all that and go through the whole process and it shows that its on the previous version, and then it automatically updates itself within 5 minutes, not even long enough to test to see if it worked or not. Maybe I'm doing something wrong with that too, I really need any ideas that anybody has because these are the main computers and they have to work.
rkshook
May 29, 2017Tutor
I am having the exact same issue...would love an answer to the question. Otherwise...its looks like a return will be hapenning soon.
