maxram
Mar 20, 2018Aspirant
Unable to connect some devices - NETGEAR Orbi AC3000 Tri-band WiFi System
Hello,
I am having problem with connecting some devices to my Wifi - (last night found that I could not get my son's Mac to connect to the Wifi)
I am running - Router Firmware Version - V2.1.2.18
Any help will be greatly appreciated
Thanks!
What is the Mfr and model# of the ISP modem? Any built in router here by chance?
What OSX version is the Mac using? What Mac is this device? Iphone? Laptop? iMac?
Try disabling the following:
Beamforming, MIMO, Daisy Chain and Fast Roaming if seen.
- maxramAspirant
Thank U for responding - I am not technically savvy - is there a limit on number of devices that I can connect - reason I ask is if all the people in my holusehold are using some device we get this problem - so issue is not really with only the Mac(be cause sometimes it connects without any issues) - it even happens when my wife sometimes turns on her Dell Windows laptop or I use my iPad (it feels like if there are quite a few devices I see this problem)
ISP is Spectrum (used to be Time Warner)
Modem is: Technicolor
Mac - Macbook Pro
Mac OS - High Sierra
I dont know where do I go in and disable this:
How many devices are online and connected at one time?
Orbi system should be about to handle upwards of 30 devices est.
You can find these settings under Advanced/Advanced settings/Wireless Settings
I would also set Manual Channel 1, 6 or 11 on 2.4Ghz and any open unused channel on 5Ghz. Try 48 to start.
Set WPA2 and AES only.
