maxram
Mar 20, 2018Aspirant
Unable to connect some devices - NETGEAR Orbi AC3000 Tri-band WiFi System
Hello, I am having problem with connecting some devices to my Wifi - (last night found that I could not get my son's Mac to connect to the Wifi) I am running - Router Firmware Version - V2.1....
maxram
Thank U for responding - I am not technically savvy - is there a limit on number of devices that I can connect - reason I ask is if all the people in my holusehold are using some device we get this problem - so issue is not really with only the Mac(be cause sometimes it connects without any issues) - it even happens when my wife sometimes turns on her Dell Windows laptop or I use my iPad (it feels like if there are quite a few devices I see this problem)
ISP is Spectrum (used to be Time Warner)
Modem is: Technicolor
Mac - Macbook Pro
Mac OS - High Sierra
I dont know where do I go in and disable this:
Try disabling the following:
Beamforming, MIMO, Daisy Chain and Fast Roaming if seen
maxram
I went into Advanced Wireless Settings and found the following: (should I disable the Daisy Chain Topology)?
Backhaul Topology
Daisy Chain Topology is check marked
Beamforming, MIMO and Fast Roaming are unchecked
- FURRYe38Mar 20, 2018Guru - Experienced User
Yes disable Daisy Chain as well.
After making these changes, see if the problem continues. Seems like something maybe causing devices to drop connection or being a connection hob maybe and something could be preventing all devices.
I would test this out when people get home. Leave the Mac Book connected, then have each other device connect to the wifi one at a time. Not all at once. I would ask your users to have them be present with you so you can see whats happening at each stage.
